pearl 2004 problem
vendy
pearl 2004 problem
Postby vendy » 24 Nov 2007, 08:31
I have a problem with Pearl 2004.I create palettes for colors,pan/tilt,gobos,etc. and then create memories using the palettes.
My problem is that when i update a palette , memories that use this palette don,t update it with changes that i made.The palette is updated,but the memories don't update it.The second problem is that when i patch fixture(s) on pages of fixtures 2 & 3 i can't use lamp on & lamp of command.Every fixture that i patch on this pages can't strike lamps
Please give me a advice what to do
Postby niclights » 25 Nov 2007, 16:00
Odd.
Is memory definitely storing palette reference (Pxxx in LCD)?
If so, is this problem true for all fixtures - or perhaps related to fixture page location?
Regarding Macros and FP2/3 it is possible this is new bug.
vendy
Postby vendy » 25 Nov 2007, 17:06
YEs.Memory storing palette reference.Example : LCD shows pan/tilt P17
niclights wrote:Odd.
Postby niclights » 25 Nov 2007, 22:04
All fixtures?
vendy
Postby vendy » 26 Nov 2007, 05:31
Absolutely All fixtures.Yesterday I spoke with Liz Berry (she is my friend),and she told me that "The only thing I can think of with your memories problem is that if you use the 'record stage' function when you record the memory, it doesn't use presets for some reason.", BUT i don't use record stage function.
niclights wrote:All fixtures?
Postby niclights » 27 Nov 2007, 00:12
This is very strange.
Normally the only time palettes become absolute references is when they are HTP, but unless you have created some rather unusual personalities I can't see why this would be the case for colour/pan/tilt/gobo etc.
I will try and play with this & check on the Tiger.
I will also try and speak to Avo again about the number of unanswered questions here.
All time dependent of course!
Users browsing this forum: Bing [Bot] and 28 guests
