How to control Shape size and speed by playback faders
Ashley
Postby Ashley » 15 Nov 2007, 16:19
How do i link a shape size and speed to a playback fader?
Ashley
Postby Ashley » 15 Nov 2007, 16:21
Reply by Nic in PM
You just need to set to mode2:
[edit times]/playback SWOP and then softbutton G toggles through modes 0-1-2.
Also, when you record a memory you can save it ready in this mode by pressing numeric 2 just before the playback SWOP to store (LCD prompts this at the top of the screen).
Mode 2 and shapes works in conjuction with timed/static settings for size & speed. ie. static will not be affected by fader and timed will. This is set from Shapes/Playback Parameters. Since 2004 software both are initially set to timed by default.
/nic
Ashley
Postby Ashley » 15 Nov 2007, 16:22
Thx for the fast reply.
I tried that already, but i want to be able to set size AND speed for the shape by using different playback faders. I can't get that to work.
The one keeps overruling the other.
But i have seen someone do it.
any tips on that?
Postby niclights » 16 Nov 2007, 00:32
I understand why you would want this but unfortunately it is not possible. You can set size & speed together on a single fader but you cannot split control across two for the same shape. It must be specific to the shape contained on the playback. This has always been a compromise on control.
Ashley
Postby Ashley » 16 Nov 2007, 14:14
Thx for the replay, but i have seen this work on a pearl 2004 during a show, the LJ explained me how to do it....but ofcourse so fast i can't remember exactly how :?: (he was explaining during a show) i untherstand it is not possible to simply link 2 faders to 1 shape, but maybe he figured out a work around.
i will ask him how he did it and post this asap. Maybe other people know how to manage this can also give some suggestions.
I realy want to get this to work, cause it is ideal for busking live shows with minimal programming time (like there is any programtime on most shows :? ) and adapting movements to music.
Postby niclights » 16 Nov 2007, 18:25
I really think you are mistaken. I'll gladly be proven wrong though!
For busking I always run shape (usually pan+titl) in mode2 with size & speed set to timed (to allow fading in mainly) and origin coming from palettes.
Ashley
Postby Ashley » 21 Nov 2007, 19:12
sad to say you where right, i spoke to the LJ and he confirmed only using timed shape speed, and static shape size.
At certain speeds, the size of a shape gets limited by the speed of the MH fixtures. This made it look like size is adjustable, seperate from speed;
making it look like small fast movement adjustable to large slow movement. As an extra he labeled the shape playbacks as W & S which i figured for width & speed, but turned out to be Wash & Spot.... :oops:
He also conviced me that this function is not so usable considering the difficulty of controlling a shape like this. (Keeping your ML on the stage could prove to be an issue)
I tried achieving this by merging/combining shapes, but the 'problem' of the last playbackfader being raised overruling the 2nd last playbackfader sent what little hope i had down the drain.
Postby niclights » 22 Nov 2007, 01:12
Yep.
Just remember to not record P/T position in the shape otherwise mode2 will cause the origin to fade as well as control size/speed. Get P/T from palettes, other playbacks or wheel in and you're safe!
