Im using the Pearl 2004, currently i only know how to set the chase speed if the fader was the last one up. But if i have raised another fader after that, how do i get back to edit the chase parameters of the previous chase?
A friend told me to copy the chase, raise the new fader and then edit from there. But there should be a proper way right?
Changing chase parameters if chase fader was not the last on
Hit [Connect] (Blue button next to the wheels)
Hit Swop button of Playback containing chase.
You can also stop the chase from 'connecting' automatically by changing the 'auto-connect' user setting on page 3, or [AVO Shift], User Settings softbutton.
Note: It is possible that the chase you want to connect to is not available when you have changed page, ie. the Swop LED does not flash. The solution is to change back to the page containing the chase. This is a known fault!
Nic.
Nic.
Users browsing this forum: No registered users and 115 guests
