I have tried to see if there are any loose devices, cables etc. they all seem fine. the led,s next to the driver chips stop flashing as does the T bank led.
It happens on a single fixture, no fixture. cant get a common method to do it, it does it all the time
dmx shut down
capitanbob
capitanbob
dmx shut down
Yes I have called service, to be honest I love the Pearl, I was looking to look for another console............... but the response and information I had from your tech dept has inspired me.. AVO is a leader in FOH.
long live the king
long live the king
capitanbob
sorted
The console went back to avo, the fault was in the TMC area of the board. If you suspect this fault a light tapping in the area will identify it as it is a solder issue
capitanbob
Re: sorted
capitanbob wrote:The console went back to avo, the fault was in the TMC area of the board. If you suspect this fault a light tapping in the area will identify it as it is a solder issue
The desk had to go back as the fault was still present, it only happened in takeover mode. Tim in service was able to sort the problem by replacing the TMC chip. Desk has been faultless ever since.
