Hi
Is it possible to copy and transfer one avo expert to another in order to have a fully cloned back up desk
If so how is this done please?
Regards
Dave
Expert cloning
Re: Expert cloning
You can save you show file to a USB stick and load that up on a second console, when loading a show the console must be the same software or newer than the software the show was saved in.
Alternatively if you want to network the consoles together you can use TitanNet Backup to transfer the show file from one to the other. The multi-user function can be used to have both consoles controlling and editing the same show; this can be used at the same time as backup mode. In this case both consoles must be on the same software version.
In either case the consoles can be any Titan console including the Titan PC Suite software (e.g. for Titan Mobile or T3).
You normally shouldn't need anything other than the show file, you can use a recovery USB stick to perform a clean install of the operating system and software.
