Hi
Sory if imam i wrong topic i have one problem pls could you jelo me.thanks
I have created an effect that i have paused with the bpm master and i now want to record the position they have stopped in. i have tried using the record stage option but that doesn't seem to be recording my position. is there a way to record raw dmx for pan and tilt or another way of doing this?
thanks for any help
Recording position of paused effects
Re: Recording position of paused effects
Unfortunately there is not a straightforward way to do this. In Titan shapes and effects are processed as a separate layer on top of the attribute values that can be seen on the wheels and are recorded into cues and palettes. Shapes along with masters are applied immediately before the values are sent as DMX and the software does not attempt to calculate from the DMX what the equivalent attribute value would be.
thanks for the answer
Users browsing this forum: No registered users and 67 guests
