Set legend picture library missing.....
nflutter
Postby nflutter » 27 May 2024, 21:30
TM with v16.
Just started a new show from scratch and when I go to set a legend I'm not seeing anything in the picture library...... just says 'imported'.
Method.....
Set Legend
hit palette
'Picture' from softkeys
Library tab (3rd tab with picture icon)
I should get a library of preset images in type groups, like position, gobo, colour etc.... All i get is one heading that says 'Imported' and one image that I imported for lock screen, no other headings, no other images.
I'm trying to get the colour 'squiggle' when I create a colour palette, I'm just getting text 'palette no.'
All my other shows, which are basically just rewritten from an existing show, work as they should. It's only for this new 'clean' show.
Any help appreciated.
Re: Set legend picture library missing.....
Postby Gregory » 27 May 2024, 23:55
The factory icon library is included as part of the personality library installer which you can download here. This should normally be installed along with the software but there shouldn't be any harm in updating it.
In principle the automatic colour legends shouldn't require the factory icons to function however perhaps something has deleted or modified the directory where they are all supposed to be stored. The personality installer mentioned above should create all the required directories if they are missing.
nflutter
Postby nflutter » 28 May 2024, 07:43
Perfect!.....
That sorted it all out, icon library back and colour palettes squiggle all good.
I'd forgotten it actually was a full clean install not so long ago and I hadn't yet started a clean show file.
Thanks Gregory!
Users browsing this forum: No registered users and 86 guests
