Color cues don't mix
mafdy10
Postby mafdy10 » 22 Apr 2024, 04:46
Hi I am creating a fixture for my 10 channel rgb led bar and I can't get the colors to mix using the faders after setting the cues it just shifts quickly without any color blen and when I patch it as a dimmer it works fine but I need to create a fixture for it
Re: Color cues don't mix
Postby niclights » 22 Apr 2024, 10:07
To control the RGB level by fader, clear the programmer, select the fixture(s) place just the one component (ie. red, green or blue) in the programmer at 100% and record to a playback making sure the record mode is set to 'Channel' then set the component value to 0%. Repeat for all components. Then set all the playbacks to mode 2 (via [Options] or [Edit Times].
Users browsing this forum: No registered users and 113 guests
