Fixtures stay on, even with Dimmer at 0%
tn_event
Postby tn_event » 25 Dec 2023, 22:31
Hey Guys,
I have a reappearing Issue on the Tiger Touch 2 Console.
I'm running Titan 15.1.
After loading a show two groups of fixtures would stay on all the time, even if the Dimmer is at 0%.
There are no active playbacks, no dimmer values. They will turn of if I remove all colors in the programmer.
The only fix is to repatch the same fixtures on the existing ones.
After storing and reloading the show, the same thing happens.
What could be the issue?
Thanks for any ideas.
Cheers
Patrick
Re: Fixtures stay on, even with Dimmer at 0%
Postby icke_siegen » 03 Jan 2024, 12:02
Can you please tell which fixtures these are? Also maybe you can tell which personality version it is - you find this via open/view and then click the button of one such fixture - this open the Fixture view. Then in the right pane slect the Personality tab and scroll all the way down - it should look similar to this:
I have the feeling that maybe it is a personality thing.
But it might also be a show thing - a playback which is hidden or a master. You would find this via the show library...
tn_event
Postby tn_event » 09 Mar 2024, 23:35
I have the exact same Problem. After Loading a Show - Fixtures stay on, even if Dimmer is at 0%, rewatching fixes it.
Sometimes the same thing happens if i swop the fixtures, too. No solution, yet.
tn_event
Postby tn_event » 09 Mar 2024, 23:37
Same Problem here on Tiger Touch II, running 15.1.
Any Solution, yet?
Users browsing this forum: Bing [Bot] and 27 guests
