T2 - Midi button for Tap Tempo
djsky
Re: T2 - Midi button for Tap Tempo
Postby djsky » 31 Mar 2023, 16:14
Ok - help.
I’ve got the macro, made my playback, and copied the macro to a playback window…. But I’m stuck on the part that says “create a trigger that fires the macro”.
I want to fire this macro from a static playback on my TM.
Postby icke_siegen » 31 Mar 2023, 16:19
djsky wrote:...
Ah okay - this part stems from the original question with a 'MIDI button'.
In order to make this from a static playback instead of from a trigger simply move the macro from the palybacks window to the static playback button.
djsky
Postby djsky » 31 Mar 2023, 16:22
Yeah, tried that, still no worky. It’s neither changing my Avolites bpm1 or sending out the dmx of the playback 901.
Postby icke_siegen » 31 Mar 2023, 17:19
Which Titan version are you using?
djsky
Postby djsky » 31 Mar 2023, 17:22
V 14.0
Postby icke_siegen » 31 Mar 2023, 17:31
I'll check this later. Maybe you can use the log collector and send me the logfiles? Sometimes they reveal the issue...
s.beutel@trendco.de
Postby icke_siegen » 02 Apr 2023, 09:39
My bad - I suggested to copy the macro to a handle, but this breaks this macro. You need to MOVE it to the button where you want it, then it works.
(I updated the Usage hints in my previous post).
djsky
Postby djsky » 25 Apr 2023, 19:11
Finally got round to sorting this, and it works perfectly!
Thanks ever so much!
Users browsing this forum: No registered users and 79 guests
