The issue that I’m facing is that I’m trying to set a gobo into a certain position, say it’s 58 on the gobo rotation, but once I’ve come out of that cue and used the same light for a different gobo and then gone back to the first cue the position of the gobo has changed but the rotation value has stayed the same.
I’m not exactly an expert at the lighting board, which is a Avolite Quartz Titan, so any help would be highly appreciated
Gobos not retaining its position
CallumArny
Re: Gobos not retaining its position
The safest thing is to try and record this in 'Record Mode Fixture' which saves all channels of the chosen fixture - most likely you have saved it in 'Channel' mode, and some values were not included.
