Having 12 songs.
When song 5 starts it stops after 2 seconds, kind of just playing the first cue.
I unlinked. The song runs smoothly in winAmP and so does the timeline.
Linked it , the song stops at 2 sec.
Would like not to loose any of the timeline values.
When going in tableView the times are right.
Any hint how I managed to do that or how I can reverse it?
Song stops after 2seconds in timeline
Re: Song stops after 2seconds in timeline
It actually releases the timeline rather then stopping to be precice
The main thing to check would be the start time and duration of the timeline to ensure that it covers the correct range. By default timelines will release outside of this range so that might explain it especially as the default duration and release times are two seconds. In addition to that, it is possible to set an offset between the external time and what is used internally, in which case the start time should match the time as it is shown internally rather than from the external source.
If you are still encountering issues perhaps attach or provide a link to your show file. If you prefer you could attach it to a Help Desk support ticket.
Nope.
Start time is 5:00:00.00 and duration is at 05:04:04.36.
So that looks o.k.
So that looks o.k.
