Is there a way to override group masters?
For example, I set my group masters to 50pc on a fader, but want a different flash button (not the group masters one) or playback button to bring those fixtures to 100pc dimmer with a colour or shape.
Override group masters?
Re: Override group masters?
You can flash and unflash an arbitrary group master with a macro. Additionally you can fire that colour or shape playback with a macro, possibly the very same macro. So, yes, it's possible.
So to fire a macro at the same time the cue would have to be a cue list rather than just a cue? Or can I fire a macro along with a simple cue?
Fade out times would be a problem then no?
As for the separate Cue: I'd also fire this through the macro. Thus, a normal cue would do, and you'd simply place the macro onto your handle. Fade Out times: should work on the group albeit I've not yet tried this. It would work for the extra cue tho.
You can give me a shout at s.beutel@trendco.de and we work out the details.
I just tried it and it works as expected, like this:
This requires Titan v13 to work (not sure about v12). Also, you need to MOVE it onto your handle. Copying the macro will break it.
<?xml version="1.0" encoding="utf-8"?>
flashes (and unflashes) a playback and a group master
Sebastian Beutel, July 2020
idea/request: DJSky, see http://forum.avolites.com/viewtopic.php?f=3&t=6428
<avolites.macros>
<macro id="wiki.Macros.FireFlash" name="fire pb 10 and group 100">
<description>Flashes PB 10. flashes group 100</description>
<start>
<step>Playbacks.FlashTimedPlayback("cueHandleUN=10")</step>
<step>Group.FlashFaderTimed(userNumber:100, true)</step>
</start>
<end>
<step>Playbacks.ClearFlashTimedPlayback("cueHandleUN=10")</step>
<step>Group.FlashFaderTimed(userNumber:100, false)</step>
</end>
</macro>
</avolites.macros>This requires Titan v13 to work (not sure about v12). Also, you need to MOVE it onto your handle. Copying the macro will break it.
Users browsing this forum: No registered users and 79 guests
