Multy cell effect editing problems
bercic
Postby bercic » 03 Aug 2019, 22:00
I have 4 sunstripes patched in 10ch mode. titan v 11.3.
{select group},
{shapes and effects}{shape generator}{crate}{dimmer}{dimmer spread}{run on sub fixtures (linear)}
[10] {spread}
{deselect group}
{select same group again}
[5]{spread}
value does not change.
in short, if you are creating a multy cell effect using run on subfixtures (linear) shape, if you deselect your fixtures you loose the ability to edit the parameters of the shape. if you record and include the shape you regain the ability to edit it.
found this when i tried to make the odd fixtures run in reverse direction. had to record two separate effects
phb
Re: Multy cell effect editing problems
Postby phb » 05 Aug 2019, 12:31
I wasn't able to reproduce this in 11.3 release. Could you confirm exactly which fixtures you're using, and how you're deselecting / reselecting the group?
Thanks,
Pete Bridgman :: Avolites
bercic
Postby bercic » 06 Aug 2019, 16:11
hi
i made a video. I noticed that if you select all of the fixtures again you can edit it. but not if you select only odd or even lights
link: https://youtu.be/5sumP47w5mU
let me know if you need an explanation of the video.
