I have two “dimmer” attributes on some of my fixtures.
Release time works fine on colour and one of the intensity dimmers (over a timed period of 2s they slowly fade back to their previous values, but the other dimmer attribute simply “snaps” back to its previous value.
Release attributes not releasing over time
- sideshowbond
Re: Release attributes not releasing over time
this sounds like a bug I reported which is going to be fixed in the next release
It's possible that this has been fixed with the release of 11.3 (Release notes #48 "Timed release ignores HTP controls" [#77746]), assuming you are referring to what happens when a playback is unlatched (i.e. the playback is not assigned to a fader (if it is assigned to a fader, the HTP intensity values will fade out using the "Fade out" time)).
Is this issue resolved using 11.3? If not, please could you let me know:
* What fixtures you're using, in which mode
* Where the playback in question is assigned to on the console
* The steps you're following to perform the release
Thanks,
Thanks,
Pete Bridgman :: Avolites
djsky wrote:I have two “dimmer” attributes on some of my fixtures.
Could you provide us with following information (previously requested by phb):
