Midi Trigger Help
fenderdude2000
Midi Trigger Help
Postby fenderdude2000 » 28 Jun 2018, 00:41
I'm running Titan Mobile and trying to use a Midi pad Akan MPD226. It has 5 pin Midi out. I used this about a year ago and I swear it just plugged in and worked right away.
I can't get the stimulus to show any kind of signal coming in when I try and assign a Midi button to one of my faders. I've tried every setting under the Midi triggers and nothing seems to work.
Any ideas?
Re: Midi Trigger Help
Postby icke_siegen » 28 Jun 2018, 21:23
Check the settings of the MPD 226 - you can disable MIDI output (so that it only works via USB), and I believe this is the default setting. Have a look at the manual: http://b8e57dc469f9d8f4cea5-1e3c2cee902 ... 3cf920.pdf
MIDI to DIN: Determines whether or not MIDI data is sent to the MIDI Out (On) or not (Off).
MIDI data will be sent to MPD226’s USB connection regardless of this setting.
fenderdude2000
Postby fenderdude2000 » 30 Jun 2018, 21:26
that was the problem. Thank you so much you saved the day just in time!
