I have found that when using Titan Mobile (10.1) if I open the "Active Playbacks" window, the buttons are very small and it is not possible to increase their size. Therefore it is not possible to see which playback each button refers to as the text for the associated playback will not fit on the button. I used to use this workspace a lot in Titan One 9.1 but it has now become pointless using this workspace due to the fact that the legends will not fit on the available button size. I think there might have been mention of a number appearing on the button but a number is not much help in my situation.
I believe Nick confirmed that the button is "broken" but just wanted to check on this and to see if it is destined to be fixed in the next up-date. I have searched around but could not find confirmation that it will be addressed. Apologies in advance if this has already been confirmed.
Titan Mobile button size in active playback window
Re: Titan Mobile button size in active playback window
I do recall discussing this although I cannot find the details at the moment. While it is true that there is currently a fault that prevents the button size option in the Active Playbacks window from working like other handle windows, the button size does vary depending on the window size and screen resolution and the text size option does work. So depending on requirements it might not always be a problem or can be worked around. The number currently refers to the Pearl Expert pages.
As a general rule details of development are not made public for various reasons and I am not in a position to say for certain but all being well I believe the button size should work the same as other handle windows in the next version along with some changes to the page number.
