Hi, running Version 8 on a Pearl Expert (white, non-pro) with Touch Wing. Have found 2 minor annoyances or possible bugs (unless I'm an idiot and missing something, which is certainly possible LOL).
1: When I start up the console Grand Master is disabled, I re-enable it, next time I start up it's disabled again.
2: Also when I start up, the Attribute control on the wing is not there, I go to user settings and it says it's on the Touch Wing, if I change it to on the console and then change it back to on the Touch Wing it shows back up, when I restart I have to do it again, every time. These are the controls on the lower right of the Touch Wing screen for attributes.
Any ideas?
Thanks,
Dave
2 minor annoyances/problems V8
Re: 2 minor annoyances/problems V8
Same problem for me on Tiger touch and Tiger touch 2 also with new show grand master disable.
The same for me plus a strange curve when fading off quicly cues: fixtures and dimmers are taking Time to be completely off though I have no curve recorded. I've fixed the problem by changing the release Time of cues from global to 0 sec on every cue but it's tedious (I'm French and not sure of this last word!!!!)
Any thoughts on this?
So is this normal behavior or a bug?
illumn8r wrote:So is this normal behavior or a bug?
The wheels displaying on the console instead of the touch wing is definitely a bug. My Pearl Expert is doing it too, though I haven't seen it resetting on startup; for me, the bug kicks in if I change the wheels from Levels to Fade Time. I usually run with Grand Master disabled, so I can't share any info on that issue, unfortunately.
Sustantivo
Fixed in V9
I posted this for closure
Users browsing this forum: Google [Bot] and 16 guests
