The option to be able to connect playback sections together so that when you press the page + or Page - on the console it also switches the connected wing part.
For example the main section on the Arena and the bottom section on the wing and leave the top section on the current page.
(this is in addation to the set list bug where the selected pages of the wing(s) are not stored in the song)
Titan Feature Requests
Re: Titan Feature Requests
It would be interesting in Cuelist to have an option to apply Effect Speed to tracked effect. So we could Multiply or Divid the speed of one or more effect(s) without record it (them) again.
Enjoyyour AVOLife
Best
Stéphane
Enjoyyour AVOLife
Best
Stéphane
Undo time stamp
Just happend to me that i went to far back by mistake and could not restore... ty god for avtosave
A Goto Top function for cuelists key profiles.
i.e. if first cue is 1, pressing the 'top' button will go to cue 1
if first cue is 0.5,... go to cue 0.5
Useful, for example, if you're building Intensity/Fx CL in a cuestack style : first cue is plain @full for all fixtures, following cues are dimmer fx.
capture dmx function.
when turing, you could connect the festival console to titan either via dmx in or artnet. than with the same patch as the house console you could capture dmx values for fast palette building.
(for example the house console loads a position, you capture the dmx values and store in a position palette)
for better understanding im adding a link to the chamsys manual chapter 10.16 https://secure.chamsys.co.uk/help/documentation/magicq/ch10.html
Enhancement to cue list window:
In 10.1 we now have live cue in light blue and incoming in dark blue which is a great improvement. Also when on an external screen the next/current cues are kept visible ie do not disappear off the bottom of the screen - this is great but a really handy additional thing would be this...and its got to be easy to do...
Have incoming cues that are Follow cues colour coded as well.
So you can see at a glance if you need to press go for the next one, or if the next one or series are follow ons.
Eg if its a standard cue then it is dark blue as now, but if its a follow on then it could be red for instance.
* Possibility to change Playback Options for mutiple playbacks at the same time (f.e. choosing size master for 50 effects);
* Possibility to run multiple workspace windows of the same type (f.e. 3 playback windows and 2 groups windows but different pages)
* Choosing playback by user number (the same way as we can choose groups <group><user_number>, fixtures, pallets, macros etc.). Maybe <shift><playback><user_number>?
Possibility to export fixtures workspace window to pdf. It gives the look what the rig looks like.
CITP and/or NDI stream window to allow you to see preview or output from Media Server or switcher.
Nobody need a third display for Titan???
Really??
Really??
Keyframe-Shapes should support Off/Release in frames. Example: make a white bump KFS on whatever the background colour might be. In this very simple example, one frame should be 'white', the other frame should be 'Off' - and should be the colour value set by other palettes/playbacks at runtime.
Toggle Blind/Live for the internal Capture. And please don't hide this in some system setting - must be accessible so that it can be placed on a button, e.g. by a macro, and be change by one click.
implement a way to do a FULL reset to factory defaults for the PC suite. Essentially this would mean to delete the user settings files in %appdata% (Roaming and Local). E.g. it sometimes happens that the virtual panel or the virtual keyboard/sketch pad doesn't appear at all, due to wrong entries in these files. Unfortunately, these files even survive a complete uninstall/install. Hence, we need a dedicated program or option. Might be a separate program, or might be a startup option.
One of some examples: viewtopic.php?f=3&t=4321&p=15750&hilit=%25appdata%25#p15750
Also, this would circumvent problems with corrupt shutdown files.
P.S. current discussion about this on facebook: https://www.facebook.com/groups/Avolite ... 023544064/
- Add a fifth option in the Key Profile keys list (Black Key, Blue Key, Grey Key and Touch Key) to change the behaviour of the screen legends of the playback faders so it behaves like a touch button where we can assign a Key Profile command (Go, Latch, etc.). In summary, it would act as a third button for the consoles where there are only two buttons for each fader (or a fourth for the ones where there are three buttons). And we would have the choice between having the actual behaviour (when we touch the legend it opens the Playback View, second touch opens the Cue View) or having this new "button like" feature.
- Add one "Go to the top" Key Profile function for cue list. When this one is applied to a key and the key is pressed, it will go to the first cue.
- Add a Fader Playback window when we want to have some faders on the screen.
- Add a second sort of Block Shape that will freeze (pause) the shape in his actual state.
User variables.
It would be very usefull, especially with macros.
Users browsing this forum: No registered users and 70 guests
