Macro Editer
hamayan256
Macro Editer
Postby hamayan256 » 28 Aug 2017, 08:18
I want a macro editor so that I can edit the created macro later.
Re: Macro Editer
Postby niclights » 28 Aug 2017, 09:38
I believe this has already been requested before. Hopefully it will be possible in a future version. Note that if you have other ideas for new features in the future you can post them in the Titan Feature Requests topic at the top of the page.
yyy898
Re: Macro Editer
Postby yyy898 » 05 Sep 2017, 17:39
though it is possible with a workaround.
You can export macro's from your showfile using the macro in attachments.
You can then find it on the D drive on the consoles or the Documents folder on computers.
Then you can edit the macro using notepad or your prefered xml editor.
Then delete the macro from the showfile and import it again using the show library window.
ExportMacro.xml
exports macro number 1
(565 Bytes) Downloaded 542 times
