PEX V10 issues/bugs
EricS
PEX V10 issues/bugs
Postby EricS » 29 Apr 2017, 03:58
I have a pearl expert pro running version 10
1st issue. I have the back light of the internal LCD set to a lower value but every time I restart the console the LCD is at full brightness even though the control panel shows it at value for which it was set. Touching the control wheel jumps the LCD to the correct setting.
2nd issue. I have some Roscoe I-cue's patched with the pan and tilt swapped, but on restart of the console, The fixtures are reverted to normal pan and tilt even though in the Edit patch menu they are shown as swapped and must deselect and reselect the swap option to get it back.
3rd issue. Since the upgrade to version 10 the bump and swap masters are not working. I cannot find where to reset/reactivat these matters.
Users browsing this forum: Google [Bot] and 61 guests
