Quartz + External touch monitor?
Avljud
Postby Avljud » 03 Feb 2017, 14:00
Hi!
I'm considering buying an external touch monitor to my Quartz console. I guess that I connect with the DVI and a USB and that it has to be Windows compatible. Does it work? Does it work if the monitor is Windows 8 compatible? It's disturbing to have to use a mouse for the external monitor. Is there anything else that is important to think of? Anybody?
Thank you!
chrisletens
Re: Quartz + External touch monitor?
Postby chrisletens » 09 Mar 2017, 10:32
you will need an usb hub if your wing is connected... there aren't enough usb sockets on the desk.
clublights
Postby clublights » 09 Mar 2017, 16:56
A powered USB hub*
most touchscreen should connect just fine without driver install. best answer is to test.
