HI there
Not sure if its supposed to be this way or its a bug, but when i set master overlap and time for pallets its works fine, the only thing that is odd to me is if i later on with overlap still set, hit a fade time via num pad, it fades all fixtures at the same time ignoring overlap value. running v10 on a mobile.
Best Regards Urban
Palette overlap
Re: Palette overlap
I think the logic is that when you enter the numeric menu you are overriding both the time and the overlap as both values are set in that menu.
Users browsing this forum: No registered users and 72 guests
