compatible graphic tablets
I just found a Genius New Sketch 1212 on ebay and I'm wondering whether or not this work with the Pearl 2008. This is not the New Sketch HR II model - just a New Sketch 1212. If anyone knows whether or not this will work, I'd appreciate knowing. If not, can anyone recommend another compatible tablet and/or where to find an original graphics tablet? They do seem to be hard to find.
Re: compatible graphic tablets
I found à ggenius hr1212 not a hr1212iii ! Is Thérèse a compatibility problem with a Pearl 2010 ?
Best regards
Laguii
Best regards
Laguii
Bonsoir ,
I bouger A Genius hr1212 with have a db9 female out connector .
Do you Know the pin câblage for db9 to db25 mâle .
It's for plug m'y hr1212 on the serial port of the Pearl 2010.
I change the cable , but the graphic tablet hr1212 not working!!
Best regards
Best regards
Hi Laguii
It's been many years since I posted on this topic, but I recall that since then I found 3 Genius graphic tablets over in England (2 still new in box) that I bought that all work fine with the Pearl 2010. I even printed out the overlays that go on them. I can check on the pin-outs for the db9 to db25 for you.
Laguii wrote:Bonsoir ,
Best regards
Thank you very much for your answer , And excuse my English...
I waiting for your plan wiring , Maybe in pdf or jpeg as you want.
I'm enjoyed to Know the hr1212 work fine on the pearl 2010 !!!
Best regards
Best regards
rcr53 wrote:Hi Laguii
It's been many years since I posted on this topic, but I recall that since then I found 3 Genius graphic tablets over in England (2 still new in box) that I bought that all work fine with the Pearl 2010. I even printed out the overlays that go on them. I can check on the pin-outs for the db9 to db25 for you.Laguii wrote:Bonsoir ,
Best regards
Yesurday i finale found the plug mode of the db9 mâle to dB 25 mâle .
After à court test the table hr1212 si fonctioned !!! Cool!
Now i just need to found the overlay....
Best regards
Users browsing this forum: Google [Bot] and 21 guests
