problem storing only some atributes in a palette
cooldeep
Postby cooldeep » 07 Sep 2016, 01:16
hello
I have used a Pearl Tiger for some years. I was used to store a pallete only with the attributes that i have change.
Example on the Pearl Tiger:
I can save a position palette only with pan value or tilt value.
I can save a color palette on a LED fixture with only one color from the rgbw. So I can have a full white palette and another where white is applied on any other color.
Now i have a Quartz with Titan v10.
When I save a "position palette" only with "pan value", the quart saves the "tilt value" as well.
Same problem when I try a "color palette", it saves all the values from the "color", even the atributes that i don't whant to be saved in a palette.
Where and what must I change, so a palette is saved exactly with the values I try to record and not all the values from all attributes in "color" or "position" ? I didn't try yet the exclude function, because it is time consuming, I whant the console to save by default only the values that I edit.
Another problem with palettes that I have notice is that some times when i press a number on the keypad to change the next palette fade time the quartz dosen't apply the color palette from the palettes on the touch screen. If I don't press a number on the keypad, than the palette from the touch screen is always applied. I didn't notice this problem with the position palettes.
Any ideas ? :)
Re: problem storing only some atributes in a palette
Postby niclights » 07 Sep 2016, 01:25
To record just values in the programmer change the palette record mode to [Record by Channel in Programmer] (toogle softkey E in Record Palette menu.
I can't think of any reason why a timed palette would not work. I have never seen this.
cooldeep
Postby cooldeep » 07 Sep 2016, 02:18
I never presed the palette button after i have had pressed the "Record" button.
Now i figured it out.
Edit what I need -> record-> Palette -> softkey E until "Record by channel in programmer"
or
Edit what I need -> Palette -> softkey B "record Palette" -> softkey E until "Record by channel in programmer"
Thanks for the info. I have always asumed if i press "record" and i have on softkey A "Record Mode Channel" the console will record the pallete also as channel, but it seems that this is not the case. Good to know.
Regarding the timed color palette apply, if this problem will reappear, I will make a new topic about it with the exact details. It happend to me only a few times until now and i have notice it only on the CMY/RGBw fixtures and not on the fixtures with color wheel.
