- step 1 press blind
step 2 set scene
step 3 press blind and scene goes live
option to set fade time before going live would also be nice
Titan Feature Requests
Blind to live
WYSIWYG autopatch
- Could Avolites also consider supporting WYSIWYG's "Autofocus" and "Autopatch" features? This adds some intelligence to the connection between Titan and WYSIWYG: selecting spots in WYSIWYG, and transferring that selection to Titan. Or creating a patch in WYSIWYG and transferring it to Titan... http://www.cast-soft.com/wysiwyg/perform
Re: Titan Feature Requests
- Playback Options at-a-glance. The software has added so many options, especially to a cue list, that the old sidebar menu system is pretty clunky. It would be great to have a 'Playback Options Window' that could be opened, and show all of the options that are set for a playback on a single screen. implemented v10
- Ability to set a default setting for all of the Playback Options (i.e. all new cues/cuelists created in the future follow my customized default settings, rather than having to change every single one). Copy/Paste of Playback Options would be an alternative approach to this. #21242
- Ability to edit a MIDI mapping once it has been created, rather than having to delete and re-create just to change the MIDI note #21686
Import key profile
- To have global key profiles. Where you can share them between shows.
(multiple)
- Auto Open Playback View Window When a Cue list Connects (selectable from user settings) I love to open playback view when I use cue lists. #62813
- Be able to MID when autoload (selectable). In cue lists,sometimes I would like to get MID from next autoload,If this possible, Linking Cue Feature is no longer needed.
- Hilight Lowlight Profiles (like key profiles). Different Hilight methods are needed,in different focus situations. It's very usefull if I could select profiles. #62812
Change language (PC)
- Option to change software language.
We need an option in the Titan system where we can change the software language.
Right now, to achieve this, we need to change the Operational System display language. And this is bad.
In my case, for exemple, my laptop Windows come with a single language licence. So i need to use my Titan Mobile in a language i dont want to. i wish i had an option in software to put it in english , but i dont have.
Auto legend from Capture
- I have a feature request or an idea for the Titan software that might be helpful. When you record cues Titan automatically saves them like pictures that is shown over the playbacks. The next cue in the cuelist is than shown like a picture exactly the way you recorded it. Like a preview. It will include positions and colours. So for instance if you record a cue with moving heads in a cross and blue the Titan will save it like a picture for that cue. I think you might have to locate all fixtures in the visualiser though so the Titan knows the directions of the beams or would it be possible for somehow? It would give you a great preview for each channel in a quick way to see what's coming.
#61179
dev note - obvious way is to have an option to use Capture thumbnails
Consistency in Macro keys
When selecting macro for a head type there should be a consistent order of actions on the buttons, such as lamp on - lamp off - reset
At moment they jump around depending on type of fixture selected.
Workspaces
Need a new workspace option - pages. Then we could see pages as tiles with their name, copy and rename pages, change the order of them and build shows from parts of others. MagicQ has this feature and its really useful.
Workspaces
Partial Loops
Report of a request on the fb group : subroutines in sequences (cuelist/chases). Basically, partial loops, with the possibility of setting a loop count.
'Elsewhere', that looping part of a sequence is set in specific columns of the cuelist sheet, i.e. "Loop" and "Loop count".
First is the loop destination and determines which previous cue you will jump to (this could be set in Titan in the 'link' column) and the second, obviously, is the number of times you'll jump to it (which can also be 'infinite'). There's also a 'Loop Time column', with the possibility of defining a temporary loop running for X seconds.
Another way of doing it is having the possibility to create specific 'Link cues'. When you 'Go' them, the cuelist jumps to the cue specified in the fade column, and the delay column is used to set a loop count (or a 'forever' option).
#22035
#22035
Strike Doose
It would be interesting to have a direct access button to strike and doose lamp with a delay option to strike or doose selection with a delay between each fixture.
I know this is already asked but it would be awesome if the macro's are commandline based, so you can edit macro's on the desk itself whitout the need of going in the macro's xml file with the risk of messing with something wrong.
Also the ability of using variables and user input during a macro.
This still is the main advantage of Grandma above avolites.
Please make it possible to hook the bpm of for instance key-frames relative to a BPM master, so you can use key frame bumps in the correct timing, or a divider on the bpm master (half speed, 1/4 s[eed etc.). At the moment the BPM tempo's are over the whole shape resulting in way to fast running shapes
One more thing according to bpm masters would be very useful for me: I ´d like to use one BPM Master for multiple chasers. In this case, it would be very useful to not only get the speed from the BPM master but also the correct clock/step. At the moment, when one chaser is running with the BPM master as speed source (for example with tapped speed), and the second one was fired later, it runs the correct speed but out of sync. Perhaps it is a good idea to build this feature for example as clock source 1-4 additionally to current BPM masters.
Selection in Layouts
It would be interesting to have differents modes to select fixtures in layouts, for exemple be able to select by drawing a line, it would select only fixtures that handle is under the line.
It would be interesting to select individual cells of multicells fixture in layout view.
Users browsing this forum: No registered users and 70 guests
