I try to connect my quartz to wysiwyg
i have read the http://www.walterlutzu.it/wordpress/how-to-connect-avolite-titan-simulator-cast-wysiwyg/ and in the virtual console it work direct, nou i try i bij mij console i can ping the console i can see the luminex but i don't get any visual on wysiwyg R32
and ACDI 1.5 don't work in win10
what do o wrong ????
Quartz connecting to wysiwyg By Wygalizer (don't work?)
Re: Quartz connecting to wysiwyg By Wygalizer (don't work?)
Is your firewall off ?
I have had this problem allot when my norton is turned on.
yyy898 wrote:Is your firewall off ?
Yes i have my firewall off
So, let me get things straight:
When you run Titan Simulator and WYSIWYG on the same computer, you can get it to work following the guide you link to in your first post?
And when you have a separate console and WYSIWYG on your computer, you cannot get it to work?
In that case: You don't need to have the loopback adapter when connecting a console to your computer. Just make sure the network adapter from both the console and the computer are in the same range. Eg 2.3.4.5 (subnetmask 255.0.0.0) on the console and 2.3.4.6 (subnetmask 255.0.0.0) on the computer.
thats right
when in run the software in my pc it work together
when i use my avo quartz is doesn't work, i use te arnet ip adresses
and the consol see te luminex
