Pearl 2010/Tiger
Ehrig
Pearl 2010/Tiger
Postby Ehrig » 28 Nov 2015, 16:41
I've got a question about patches and fixtures!
I got 2 new Spot movingheads from a no Name Company. They arme verry simular to the Eurolite tmh 30. But the dmx adresses are different( for example: Dimmer on Channel 1 with the Original ones and Channel 6 with my ones). How can i Chance that in my Consol?
I know it from my etc Element, where that is called a custom fixtures.
So my question is: is that possible and How dös it work?
Thanks a lot
Ehrig
Re: Pearl 2010/Tiger
Postby icke_siegen » 28 Nov 2015, 16:45
Hi Ehrig,
unfortunately this is not possible 'inside the console'. You need to change the personality (you can request a new one, or make it yourself using a separate PC), and import the new personality into your console.
Sebastian
Ehrig
Postby Ehrig » 28 Nov 2015, 18:29
Ok trank you!
But what Kind of program so i Need to make my Owen fixtures?
Postby niclights » 28 Nov 2015, 19:18
You can use any basic text editor. There is more information in the manual.
Ehrig
Postby Ehrig » 29 Nov 2015, 10:50
In the Manual i found this: " You cannot currently add your own definitions to it, so you will have to load your custom personalities from disk in the time-honoured fashion".
What dos that mean?
Postby niclights » 29 Nov 2015, 11:35
That just refers to the cache. It is not important.
When using Usb the personality files need to be in a particular directory. The easiest way is to use the Copy2008 application available from the downloads page. Instructions are included.
Ehrig
Postby Ehrig » 29 Nov 2015, 16:18
So i Copy the fixture from the Website into my Texteditor and then i can Chance it. Afterwards i copy the changed fixture into the Pearl copy 2008. ant from there Transfer it into the console!??
Postby niclights » 29 Nov 2015, 17:24
Edit/create the R20 file in a text editor, follow the instructions for copying to Usb stick and then place in console to patch.
Or, as Sebastian said in his original reply, you can request the personality by filling in the form here. In order to create the personality as quickly as possible please include your console's serial number and documentation (or links to) containing full DMX mapping information. When attaching documents they must be in either .pdf or .zip format.
