Yesterday I uppgraded from v 6.(?) to 9.1. Standard recovery.
Still running same showfile and programmed some new keyframe shapes.
It start to lagg when using shapes. Dmx output freez about 1-2 second and allso flashbuttons is not responding as fast as they where in v6.
It is no lagg when programming only when I am running the show whit all lights.
32x pixelmapped tribars 54ch per fixture
40x movinglights
20x rgb parcans
6x atomic
24ch dimmer
using artnet and standard dmx total 8 univers.
no lagg in v6. What can I do?
Pearl expert v9.1 lagg
Re: Pearl expert v9.1 lagg
I don't know if you already solved your problem, but I just had the same problem and I think I've found the solution.
When you go to the DMX settings, you can see a header Art-Net. Next to it a Gear symbol for the properties.
And then you can enable or disable some properties.
Enable the Always Broadcast ArtNet.
This solved the problem for me.
This is not just darkness, it's a very dark darkness...
Users browsing this forum: No registered users and 87 guests
