Is it bugs of key frame shape??
the shape direction from left to right is ok...but up to down is not avalable....thanks for help
Re: Is it bugs of key frame shape??
i am not shure but i think the key frame shape generator uses the fixture layout that the pixel mapper uses too, so map your fixtures in the wright way so the console knows which fixtures are above the others, if that doesn't work please email the showfile to jonasnijs@gmail.com and i will check it for you.
Kind regards,
Nijs Jonas
Kind regards,
Nijs Jonas
That is correct. Key Frame Shape directions rely on the 2D fixture order set in the layout editor.
