Titan Mobile Executor Buttons
JSSound
Postby JSSound » 17 May 2015, 12:04
is it possible to use the executor buttons 11-17 as all the other executor buttons?
They have a preset of window settings (Open Attribute editor, etc). But I would like to use them for cues or chases. Is that possible?
Thanks,
Jürgen
oaksld
Re: Titan Mobile Executor Buttons
Postby oaksld » 17 May 2015, 12:51
Yes.. I delete all of the stock macros and use the buttons for everything from specials to house lights to cue list for timer on my hazer. It's probably one of my favorite features on the mobile since it only has 10 playbacks.
JSSound
Postby JSSound » 17 May 2015, 13:13
Thanks for the quick reply! I tried deleting them, but in the Forum I now found how to do that.
Open (Window Control)
Delete
press Exe button 11~17
press same button again
Jürgen
DMX
Postby DMX » 02 Jul 2015, 07:42
So here is what I do...
If you go into the show library and then macros, there is a macro labeled 'Static Playbacks Page 0' and 'Static Playbacks Page 1'
If you copy the macro labeled 'Static Playbacks Page 1' to an open static playback button, press it, copy 'Static Playbacks Page 0' to the same button, you create a toggle that goes back and forth from the page with workspace windows and a page without.
I will typically record one or two dummy static playbacks to use as indicators as there isn't anything on screen to indicate what page I'm on (fix please!!).
You can also link one of these macros to a fader playback so when fired it switches to the page you need of static playbacks.. I hope Avo expands this functionality in the future!
JSSound
Postby JSSound » 07 Jul 2015, 19:51
That's a good idea, thanks!
I will test that this weekend...
Postby Gregory » 07 Jul 2015, 20:23
If you are using the page macros you may want to lock them so that they appear on all pages. Press Playback Options softkey then the macro button to bring up the options.
JSSound
Postby JSSound » 08 Jul 2015, 13:56
Works great!
I did not know that I can change these static playback buttons and have more than one page :oops:
