Is it possible to record a shutter palette as a memory and then use the flash button to activate
when I press and stop it when i release the flash button?
I have 4 CP alpha spot hpe 300 spots and tried to do this, but I can only activate it, not stop it.
Can I change the settings on the flash button/memory/handle?
I use the Pearl Expert with Titan 9.0
Start/stop flash-button.Pearl Expert Titan 9.0
Re: Start/stop flash-button.Pearl Expert Titan 9.0
Record the strobe as a playback, set the playback to release intensity (playback options) and set the key profile action to flash. If you now set the shutter to open (followed clear if necessary), pressing the playback button will activate the strobe and releasing will return to its previous state (ie. open).
