Hello .
I have one titan mobile . I would touch control on it. What do I need to connect one more touch screen ? and , What can I do other screen? THANK YOU
TİTAN MOBİLE EXTERNAL TOUCH SCREEN
Re: TİTAN MOBİLE EXTERNAL TOUCH SCREEN
For Titan Mobile you should be able connect any touch screen monitor that is compatible with your computer and version of Windows. You should consult the quick start guide or manual of the monitor for information on how to configure it. Once the monitor is configured in extended desktop in the Titan Mobile software go to System then select Display Settings from the softkeys (may be on the Next page) and toggle the External Display setting to Enabled. Once this has been set, it will be remembered each time you start the software. The external display can be used to show any of the workspace windows and the windows can be arranged in quads, halves or as one full screen window as with the workspace area on the main display.
you can alo use an Ipad with TwomonUSB. works fine by me.
Well, we can assign another menu screen except the main menu extra? I use only my screen are expanding or?
Users browsing this forum: No registered users and 116 guests
