how to make "Update BIos" USB for Titan V6
iwankurus1
Postby iwankurus1 » 09 Sep 2013, 14:35
hi,
anyone can help me please.....
im trying to make the USB for upgrading to Titan V6
i already download the "Avolites BIOS Update Creator"
and i follow the instruction , but not succed.
after i click Install, then the message is "Failed to Create BIOS stick! (error: 2)
im using windows 7.
anybody could help me ?
Thank you
iwan hutapea
Re: how to make "Update BIos" USB for Titan V6
Postby Gregory » 10 Sep 2013, 15:55
What size is the USB stick you are attempting to use, recommended size is 2GB or less? Do you have an alternative USB stick that you can try?
iwankurus1
Postby iwankurus1 » 29 Sep 2013, 05:40
Im using 8 Gb USB Stick,
After trying with some other brand, it succed....
The problem is didn't work with all kind of USB, only some certain brand.
But now im facing other problem,
After update the BIOS, now the USB is missing from boot facilities,
It only have 2 option instead of 3,
So it cannot read or copy the program from the 3rd USB.
Now my TT is empty. I could only see the C:\ prompt on my screen.
I cannot make it to boot from USB, because its not there.
I've tried to re do & check all the bios setup base on the manual, still not work
Any suggestion ?
Regards
Iwan hutapea
Postby Gregory » 29 Sep 2013, 11:24
After installing the new BIOS, please configure it using the instructions in section 4.3 (page 8) of the V6 Upgrade Guide. Once the settings are correct, please proceed with the remainder of the upgrade guide. Note that in the new BIOS booting to a USB stick is achieved by setting the First Boot Device to USB Device.
ricws
Postby ricws » 03 Oct 2013, 17:31
You MUST use a 4Gb or smaller. Windows will not boot from any usb memory stick larger than 4Gb.
iwankurus1
Postby iwankurus1 » 18 Oct 2013, 06:45
Hi Gregory,
Thank you for your help.
now i already install ver 7
but on the process of installing the ver 6.
when i update the SSD (OCZ-solid), there is a message that say that this is not the right software (i re do it 3 times, and got the same result)
is it OK ?
i continued install the rest and succeed.
after that i install ver 7.
also succeed, then i try to run a chase program from the demo file for 2 hours.
after that the board crash.
the display gone.... replace with a colorfull moving image (chaos)
i tried many times to restart the board and not succeed.
i always got a blank white screen.
i could not even get into the BIOS
i tried to hard reset and still not succeed.
please help me what should i do to solve this.
REgards
Iwan Hutapea
Postby Gregory » 18 Oct 2013, 14:34
Please contact our service and repairs department by email, repairs@avolites.com, or by telephone on +44 (0)20 8955 9232. Alternatively, please contact your local Avolites distributor.
Users browsing this forum: No registered users and 143 guests
