Titan Mobile Cuelist problem
jojodadj
Postby jojodadj » 18 Sep 2013, 23:01
Hi All,
I am away with a show at the moment, had some rehearsals today and was programming a Cuelist which was fine. I used that particular Cuelist which worked fine I then added another scene to the end of the Cuelist everything in that cue working fine except the Cuelist playback slider was not controlling the HTP levels, they were just on. And then if I triggered another cue on the same stack it would snap the HTP levels to 0 and then fade them back in as per the times programmed in the cue. I then saved and restarted the Titan software and the cue was working as it should with the fader controlling the HTP. Very strange.
Any theories?
Regards
Joe
jojodadj
Re: Titan Mobile Cuelist problem
Postby jojodadj » 23 Sep 2013, 22:41
Anyone have anything to add to this?
I have just got back from the week long rehearsals and came across a few other bits. After programming for a few hours the clear light on the clear button does not disappear when you press it. Also I had 2 different occurrences where one of the executor buttons just randomly lit up when it didn't have anything programmed on it. Lit up as if it had a playback programmed and active but the second time it happened it was a different executor button. For both of these problems a reset of the software and pulling the USB out for the desk resolved it.
Joe
