Titan Mobile V7 losing workspaces and page legends
Patrik
Postby Patrik » 09 Sep 2013, 12:52
First: Good job on V7, lots of very useful things!
However, when I start a saved show in Titan Mobile all my saved workspaces are gone and all the page legends are missing.
Playback legends and set lists are all there. Any thoughts on this?
Thanks,
Patrik
Re: Titan Mobile V7 losing workspaces and page legends
Postby niclights » 09 Sep 2013, 13:09
I think this is an issue with the shutdown show, one way or another. If you save/load it will work correctly.
Patrik
Postby Patrik » 09 Sep 2013, 13:46
Yes you are correct, it works when I load the show manually. Thank you :D
john rogers
Postby john rogers » 09 Sep 2013, 15:30
Hi Patrik,
Does this happen every time you restart the software or just that first time you started Version 7 after installing?
Did/does it happen with more than one show file?
John
Patrik
Postby Patrik » 09 Sep 2013, 15:52
Hi John,
I only have one show file since this is my first show on a Titan series console, and yes it happens every time i start the Titan Mobile application.
As said before, doing a manual reload of the show file fixes the problem.
john rogers
Postby john rogers » 09 Sep 2013, 16:07
Thanks for the update.
clublights
Postby clublights » 09 Sep 2013, 16:24
Here is what I'm experiencing...
v6.1 shows will not always load up right. sometimes I have to load them 3-4 times till everything seems to load ( workspaces, groups, fixtures, palletes, Viz ) .
Once loaded correctly and saved in v7 they load correctly every time.
on restart of the console (TitanOne in my case) workspaces will not load every time
but they do load after opening the saved show file
Created new show
Made 3 workspaces save show quit Titan. on reboot of titan no workspaces
but they do load after opening the saved show file.
jojodadj
Postby jojodadj » 09 Sep 2013, 22:23
Have got the same problem here, mine does not load any masters either until I load the show manually.
Could this have something to do with the post I opened up earlier about the Titan engine not shutting down correctly?
Regards
Joe
Postby Gregory » 10 Sep 2013, 00:49
jojodadj wrote:Could this have something to do with the post I opened up earlier about the Titan engine not shutting down correctly?
Do you mean this thread?
jojodadj
Postby jojodadj » 11 Sep 2013, 14:53
Yes thats the one.
Joe
Congo Design
Postby Congo Design » 17 Sep 2013, 21:22
Hey all. I have a similar issue with two workspaces. Just upgraded from 6.1. Sorted all the tracking issues out and move in dark on my cue stacks.
All fine and ran smoothly. Restarted the console and my tracking information is lost and also I cannot "view cue". I.e on some cues I have blinders programmed at 100% and then the next cue they are tagged at 0. Show runs fine. Shutdown the console and reboot and it looses that information?
Surely you don't need to reload the show every time you boot the console?
Help!
Cheers
Dan
Users browsing this forum: Baidu [Spider] and 93 guests
