Hi Guys,
I've recently updated my Titan Mobile to 6.1, before the update i did some jobs with CLS Pixelbar Tri Colore.
And i've programmed some dimmer/rgb shapes for it, where in Titan 6.0 the software uses all the separate cells.
Now in Titan 6.1 for some strange reason the shapes only takes place for a whole Pixelbar.
Is tried different ways, apply to super fixture or sub fixture, changed the Course, offset and deg.
Off course in the pixelmapper it works fine. But sometimes u only use 4 or 6 pixebars so a shape is much faster to apply.
Hope that you understand the issue, and you could give me some advice.
With kind regards,
Nathan Joosten
The Netherlands.
Shapes run diffrent since 6.1 update TM
Nathan-Joosten
Re: Shapes run diffrent since 6.1 update TM
I can't find any problem.
The closest match to your fixture in the library is CLS-LED Pixelbar 54 or 36. Neither of these have had any changes recently. When I test a colour shape applied to sub-fixtures the spread works across the cells within a fixture as expected.
Are you using a show created in a version before 6.1?
Nathan-Joosten
Im using a new show, and always use the Showtex Pixelbar 12 fixture with 36 channels.
Because the CLS Pixelbar 36 is an older fixture with separate r,g,b.
I'm using the CLS Pixelbar Tri Colore 36.
This one
This one
The only difference between the Showtec Pixelbar 12, 36 DMX and the CLS-LED Pixelbar 36, 36 DMX personalities is the CLS has the channel assignment GRBGRB... where the Showtec uses the normal RGBRGB... order. A significant difference as far as ensuring red and green on the console correspond to the same attributes on the fixtures but both work fine with shapes on sub-fixtures.
The CLS manual linked provides no details on DMX assignment, not even total channel counts. So I cannot be certain that you are using a suitable personality but if pixel mapping is working as expected then I have to assume it is.
Please post exact steps to repeat the problem from a new show.
