Get fixture attribute value
Posted: 19 Apr 2024, 00:36
by Jorge Garcia
Hello
I have read in this forum that I can set an attribute value for selected fixtures with this API:
http://localhost:4430/titan/script/2/Pr ... lValueByIdIt works great.
There's any possibility to also get the current attribute value for selected fixtures?
Thanks!
Re: Get fixture attribute value
Posted: 22 Apr 2024, 16:00
by Gregory
Assuming the fixtures are already selected you can set the context attribute using the following command:
http://localhost:4430/titan/script/2/Programmer/Editor/Fixtures/SetContextAttributeFromId?attributeId=32It is then possible to read the value of the context attribute as follows, this will be the same as the value shown on the wheel e.g.
0.00 to
100.00:
http://localhost:4430/titan/get/Programmer/Editor/Fixtures/ContextAttribute/ValueThere are some fixed numeric attribute IDs which are listed
here. Other attribute/control IDs can be looked up using:
http://localhost:4430/titan/script/2/Programmer/Editor/Fixtures/GetControlIdFromName?controlName=PanThe
SetContextAttributeFromId won't necessarily return an error if the attribute cannot be found so you can check what it ended up being set to by looking at the property:
http://localhost:4430/titan/get/Programmer/Editor/Fixtures/ContextAttribute/IdThere are several other
ContextAttribute properties that can be queried for information.
Posted: 23 Apr 2024, 19:09
by Jorge Garcia
It works like a charm, thanks a lot Gregory!!!
