There isn't an option to convert a chase or cue list but you can move or copy all the cues in any playback to any other playback. This is relatively straightforward to do using the
Move or
Copy button and selecting the cues from the
Playback View or by
using syntax.
If you want to do the same using a macro, the following copies all the cues from the playback on fader 1 to a new chase on fader 2:
Playbacks.Editor.CopyCues.SelectAll(location:("Playbacks", 1))
Playbacks.CreateChase("Playbacks", 1)
Playbacks.Editor.CopyCues.CopyMovePlaybackCues(Math.ToEnum("Avolites.Titan.Controllers", "Avolites.Titan.Controllers.Handles.HandleController+HandleOperations", "copy"), Playbacks.PlaybackEdit.Handle, false, true, false)
Playbacks.PlaybackEdit.Exit()
The first line specifies the source cues, selecting all the cues within the playback given. The second line creates a new chase, note this function is 0-indexed so 1 is the second fader. This line can be changed to the
Playbacks.CueList.CreateCueList function to create a cue list instead of a chase. The third line
"copy" can be changed to
"move" if you prefer; as above the original playback remains untouched. The fourth line exits out of the chase or cue list record mode. You can choose to delete the original playback and move the new one if needed.
