macro copy replace group in playback and how to highlight macros ?
Posted: 17 Aug 2023, 14:44
Hi im very new in avo macros and i try to understand how to work?
i create a color piquer ( 5 cue list for tipe of fixture with 18 cues the colors )
https://drive.google.com/file/d/1PexhPN ... drive_link
in layout view craete a matrix with macros "go to cue x" ( 6 rows 1 All 2 spot 3 wash 4 beam 5 strob (jdc1) 6 rgb bar, and 18 colums for color)
and create macros to change fade time and anothers for overlap .
now im try to change de direction of the overlap ?
https://drive.google.com/file/d/1NAmY6b ... drive_link
i try in replace or merge another group (only fixture order is change) but steel not work.
and how i highlight macros ?
If someone can helpme ?
<?xml version="1.0" encoding="utf-8"?>
<avolites.macros>
<macro id="UserMacro.Allwhite">
<name>ALL WHITEv2</name>
<sequence>
<step>CueLists.SetNextCue(userNumber:4, 1.0)</step>
<step>CueLists.Play(userNumber:4)</step>
<step>Handles.HighlightHandle(handle:"Location=PlaybackWindow,60,1")</step>
<step>CueLists.SetNextCue(userNumber:5, 1.0)</step>
<step>CueLists.Play(userNumber:5)</step>
<step>CueLists.SetNextCue(userNumber:6, 1.0)</step>
<step>CueLists.Play(userNumber:6)</step>
<step>CueLists.SetNextCue(userNumber:7, 1.0)</step>
<step>CueLists.Play(userNumber:7)</step>
<step>CueLists.SetNextCue(userNumber:8, 1.0)</step>
<step>CueLists.Play(userNumber:8)</step>
</sequence>
</macro>
</avolites.macros>Code: Select all
<avolites.macros>
<macro id="Fadeintime 0s" name="Fade 0s">
<sequence>
<step>ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,60,1")</step>
<step>Playbacks.Editor.CueSelection.SelectAll(handle:"Location=Playbacks,60,1")</step>
<step>ActionScript.SetProperty("Playbacks.Editor.Times.CueFadeInTime", time:0.0)</step>
<step>ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,60,2")</step>
<step>Playbacks.Editor.CueSelection.SelectAll(handle:"Location=Playbacks,60,2")</step>
<step>ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,60,3")</step>
<step>Playbacks.Editor.CueSelection.SelectAll(handle:"Location=Playbacks,60,3")</step>
<step>ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,60,4")</step>
<step>Playbacks.Editor.CueSelection.SelectAll(handle:"Location=Playbacks,60,4")</step>
<step>ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,60,5")</step>
<step>Playbacks.Editor.CueSelection.SelectAll(handle:"Location=Playbacks,60,5")</step>
<step>ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,60,8")</step>
<step>Playbacks.Editor.CueSelection.SelectAll(handle:"Location=Playbacks,60,6")</step>
</sequence>
</macro>
<avolites.macros>
<!-- SELECT ALL CUE OFF ALL 6 PLAYBACK PAGE 60 AND CHANGE OVERLAP ANDRÉS FÉLIX-->
<macro id="100Overlap">
<name>100% Overlap</name>
<sequence>
<step>Handles.ClearSelection()</step>
<step>Handles.SetSourceHandle("PlaybackWindow", 60)</step>
<step condition="Playbacks.IsCueHandle(Handles.SourceHandle)">ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", Handles.SourceHandle)</step>
<step>Playbacks.Editor.EnsurePlaybackCueSelected()</step>
<step>ActionScript.SetProperty.Float("Playbacks.Editor.Times.CueFixtureOverlap", 1)</step>
</sequence>
</macro>
<macro id="50Overlap">
<name>50% Overlap</name>
<sequence>
<step>ActionScript.SetProperty.Float("Playbacks.Editor.Times.CueFixtureOverlap", 0.5)</step>
</sequence>
</macro>
<macro id="0Overlap">
<name>0% Overlap</name>
<sequence>
<step>ActionScript.SetProperty.Float("Playbacks.Editor.Times.CueFixtureOverlap", 0)</step>
</sequence>
</macro>
</avolites.macros>If someone can helpme ?
