set/delete Upper Limit
Posted: 21 Dec 2022, 18:01
Hello to all,
i'd like to use a Macro to set/delete the Upper Limit of a single channel of the selected fixture (a lot of Kinetic Fixture). in this moment i open Fixture view of every single fixture to remove the Upper Limit and then set the Limit with the button "Set to Current Value".
Is it possibile to do all this routine in a quick way with a recorded macro or a need to write some coded macro???
