hello, i need some help with a macro im writing at the moment.
this is what i have at the moment.
<step pause="0.001">ActionScript.SetProperty.Boolean("Programmer.BlindActive", true)</step>
<step pause="0.001">Programmer.SetBlindMode(false, 0)</step>
<step pause="0.001">Include.SelectPlaybackHandle("Location=PlaybackWindow,1,1")</step>
<step>Palette.ApplyPalette("Location=Beams,1,1", false)</step>
what i need next is a string that replaces a playback with the selected pallete without deleting te playback
replace macro
Re: replace macro
Can you please explain what you want to achieve? I don't understand "replace playback with palette without deleting playback".
Thanks.
Thanks.
Re: replace macro
Im sorry for my bad English.
What I want to achieve is that I can run a macro that can replace the info of a playback.
In my case I want to be able to chose between different strobe pallets which I kan replace in one playback.
For example.
I have a playback that does a normal strobe and with a macro I want to change it to a strobe with white.
I hope my explanation helped a little bit
For example.
Re: replace macro
Ah okay.
Maybe something like this:
That's from the wiki: https://www.avolites.de/wiki/macros/exa ... hapespread
<step>Playbacks.MergePlaybackCue("Location=PlaybackWindow,1,1", true)</step>
