how to write macro time ?
jacklighting
Postby jacklighting » 28 Feb 2019, 16:32
need to macro time fixture / programing
time fixture 1 thru 10
THX
Best Regard , Sincerely :D
jacklighting
Re: how to write macro time ?
Postby jacklighting » 28 Feb 2019, 20:35
<avolites.macros>
  <macro id="Macros.Fade" name="Fade 1s to 10s">
    <sequence>
      <step>ActionScript.SetProperty("Playbacks.Editor.Times.SetControlFadeTimeOn", time fixture p 1 thro 10)</step>
     </sequence>
  </macro>
</avolites.macros>
it wrong , i not understand
Postby Gregory » 06 Mar 2019, 00:56
Try the following:
<avolites.macros>
    <sequence>
      <step>Command.RunCommand("1 THRO 10 TIME FIXTURE 1 THRO 10")</step>
      <step>Playbacks.MergePlaybackCue(userNumber:2, false)</step>
      <step>Programmer.Editor.ClearAll()</step>
     </sequence>
  </macro>
</avolites.macros>
The first step runs a command which selects fixtures 1 through 10 and then sets the attribute fade times on those fixtures to the values 1 through 10. These times are in the programmer and can then be recorded into a playback which is what happens in the second step - in this case the playback is a single cue/memory, if you instead had a cue list you should instead use MergePlaybackStep e.g.:
<step>Playbacks.MergePlaybackStep(userNumber:1, 1.0, false)</step>
The last step clears the programmer once you are done. You can use similar syntax to set delay times or to only set attribute times for a specific attribute group e.g Intensity by using the letter I.
Playbacks.Editor.Times.SetControlFadeTimeOn is a function that you call e.g.
<step>Playbacks.Editor.Times.SetControlFadeTimeOn()</step>
rather than a property that you can set. In this case it does not take any parameters/arguments and is used to set the attribute fade time to On in the programmer (the opposite of Off), this will be applied to the currently selected attributes.
Users browsing this forum: No registered users and 6 guests
