Export macro1 thro macro10
Posted: 27 May 2018, 12:56
by jacklighting
i can export macro only macro 1. i want to export macro number 1 thro macro number 10. pls thx bro
<macro id="Avolites.Macros.ExportMacro" name="Export Macro Number 1">
    <description>Exports the macro with user number 1.</description>
    <sequence>
      <step>UserMacros.SetCurrentMacroFromUserNumber(1)</step>
      <step>UserMacros.Export(UserMacros.CurrentMacroId)</step>
    </sequence>
  </macro>
Re: how i export macro1 thro macro10 ?
Posted: 27 May 2018, 16:36
by icke_siegen
There is no way to export multiple macros at once, as this function always expects ONE macro to export.
You can change this line
to e.g.
UserMacros.SetCurrentMacroFromUserNumber(6)
which would export macro #6. However, as it is very easy to change user numbers in Titan, the idea is:
- set the 1st macro which you wish to export to usernumber 1
- run the export macro
- copy/save the exported macro to wherever you wish
- set the next macro which you wish to export to usernumber 1
- copy/save...
(rinse and repeat :) )
Posted: 27 May 2018, 16:57
by jacklighting
thx bros. :)
