Page 1 of 2
Add midi Trigger
Posted: 20 May 2018, 07:29
by kimwida
Hi.
After install v.11, I can't save my launch Pad MK2 midi trigger settings.
Even I can't see two factory triggers, there's nothing trigger.
After recording my 80 midi triggers and save show when I restart Titan, there's nothing trigger they all gone.
When I start new show, then there are two factory triggers. And it does save.
I think there was some problems in my show file when I upgraded v.11.
It's best if I rewrite my show file from new. But my show file has so many song cuelists so I can't do that.
So I want to write trigger macro. But I need to know the parameters of the two methods.
Please help me.
Void Triggers.SetPendingTargetHardware(String keyClass, MenuEventTypes eventType, String keyGroup, Int32 keyIndex, String keyName)
Void Triggers.AddMidiTrigger(Int32 mappingId, TriggerTargetData targetData, Int32 channel, PanelMidiCommands panelCommand, Int32 value, Int32 min, Int32 max, Int32 threshold, Boolean useLevelMatching)Or if someone let me know how to save trigger settings, it will be best.
Re: Add midi Trigger
Posted: 21 May 2018, 12:50
by icke_siegen
I don't have a solution, hence someone from the software dept. is asked to help. At least I managed to create some macros which do not throw an error - but they don't run. Maybe this is better to explain with these examples:
This is expected to add an item trigger:
<macro id="Avolites.Macros.AddMidi01" name="Add Midi Trigger 01">
<sequence>
<step pause="0.01">Triggers.SetPendingTargetHandle("Location=Playbacks,1,1")</step>
<step pause="0.01">Triggers.AddMidiTrigger(1, Triggers.PendingTriggerTarget, 1, Note, 0, 0, 127, 0, false)</step>
</sequence>
</macro>And this is expected to add a hardware trigger:
<macro id="Avolites.Macros.AddMidi02" name="Add Midi Trigger 02">
<sequence>
<step pause="0.01">Triggers.SetPendingTargetHardware("PlaybackSelect", OnButtonDown, "Playbacks", 1, "")</step>
</sequence>
</macro>Again, neither works for me - maybe Olie, Peter or Gregory can help.
Posted: 21 May 2018, 12:52
by Gregory
It sounds like there may be a problem with your show file which is preventing your trigger mappings from loading in version 11. After loading your v10 show file in version 11 can you check in
Log Viewer Pro to see if there any errors reported. Alternatively you could consider reporting a
support ticket to get your issue looked into.
It terms of writing a macro the following will add a MIDI trigger for the first playback swop button (Hardware) for note 11 (Note On, After Touch and Note Off):
Triggers.SelectMappingByName("Your Mapping Name")
Triggers.SetPendingTargetHardware("PlaybackSelect", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", "OnSelect"), "Playbacks", 0, "Swop")
Triggers.AddMidiTrigger(Triggers.SelectedMappingId, Triggers.PendingTriggerTarget, 0, Math.ToEnum("Avolites.Titan.Controllers.Console", "Avolites.Titan.Controllers.Console.PanelMidiCommands", "Note"), 11, 0, 127, 0, false)Example 2: Add a MIDI trigger for the first preset fader (Hardware) for Control Change 1:
Triggers.SetPendingTargetHardware("PresetFader", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", "OnValueChanged"), "Presets", 0, "")
Triggers.AddMidiTrigger(Triggers.SelectedMappingId, Triggers.PendingTriggerTarget, 1, Math.ToEnum("Avolites.Titan.Controllers.Console", "Avolites.Titan.Controllers.Console.PanelMidiCommands", "Continuous"), 1, 0, 127, 0, false)
Posted: 21 May 2018, 13:53
by kimwida
Thank you so much!!!
Could you explain "KeyClass" and "KeyName" in detail??
I want to add trigger playback on my playback window.
I usually use my launchPad mk2 to trigger playbacks in playback window.
<step pause="0.01">Triggers.SetPendingTargetHardware("playbackselect", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", "OnSelect"), "PlaybackWindow", 0, "Touch")</step>
This add trigger but not work. I think Keyclass or keyname is wrong.
Posted: 21 May 2018, 14:05
by icke_siegen
I like coincidences
- with Gregory's example I found some working examples:
<macro id="Avolites.Macros.AddMidi12" name="Add Midi Trigger 12">
<sequence>
<step pause="0.01">Triggers.SelectMappingByName("4")</step>
<step pause="0.01">Triggers.AddMidiTrigger(Triggers.SelectedMappingId, Triggers.PendingTriggerTarget, 1, Math.ToEnum("Avolites.Titan.Controllers.Console", "Avolites.Titan.Controllers.Console.PanelMidiCommands", "Continuous"), 17, 0, 127, 0, false)</step>
</sequenc e>
</macro> Code: Select all
<macro id="Avolites.Macros.AddMidi13" name="Add Midi Trigger 13">
<sequence>
<step pause="0.01">Triggers.SetPendingTargetAction("Flash")</step>
<step pause="0.01">Triggers.AddMidiTrigger(Triggers.SelectedMappingId, Triggers.PendingTriggerTarget, 1, Math.ToEnum("Avolites.Titan.Controllers.Console", "Avolites.Titan.Controllers.Console.PanelMidiCommands", "Continuous"), 12, 0, 127, 0, false)</step>
</sequence>
</macro>
Posted: 21 May 2018, 14:16
by Gregory
The
keyClass is the name of the physical button or group of buttons,
group is the virtual area on the console that the button maps to and
keyName is a name for the button (e.g. Swop, Flash, Touch, Black) which in this case is not really used.
You were almost correct, for the Playbacks window you need the following:
Triggers.SetPendingTargetHardware("PlaybackTouch", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", "OnSelect"), "PlaybackWindow", 0, "Touch")
Posted: 21 May 2018, 14:31
by kimwida
Wow!! It works perfect!!
You make my life so much easier!!
I really appreciate it.
Anyway, I found the KeyClass is case-sensitive. So only "PlaybackTouch" works.
Posted: 22 Jun 2018, 18:30
by kimwida
Just curious.
Triggers.SetPendingTargetHardware("PlaybackSelect", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", "OnSelect"), "Playbacks", 1, "Swop")
It works.
Triggers.SetPendingTargetHardware("PlaybackSelect", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", "OnSelect"), "Playbacks", 1, "Flash")
But it doesn't work. Actually it works as "Swop".
And how do I add "Playback Page -1", "Playback Page +1" , "Go", "Connect", "Cuelist +1" and "Cuelist -1" to trigger??
Posted: 22 Jun 2018, 19:15
by sideshowbond
I know it doesn't solve your actual problem as such but with a launchpad mk2 you might wanna have a look at this little gem:
http://www.avolites.de/support-downloads/midi-to-web
Posted: 24 Jun 2018, 15:38
by Gregory
kimwida wrote:Code: Select all
Triggers.SetPendingTargetHardware("PlaybackSelect", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", "OnSelect"), "Playbacks", 1, "Flash")But it doesn't work. Actually it works as "Swop".
This is because you have only changed the
keyName parameter to
Flash which as I mentioned above is not really used. The important parameter is the
keyClass which should be changed from
PlaybackSelect to
PlaybackFlash (if I remember correctly).
Posted: 24 Jun 2018, 18:57
by kimwida
Hi, Gregory.
Thanks for the right answer!!!
Could you tell me the
keyclass and
keygroup of "Playback Page +1", "Playback Page -1", "Go", "Connect", "Cuelist +1" and "Cuelist -1" button??
It's kind of tiresome to add 6 triggers in every show.
Posted: 24 Jun 2018, 19:13
by Gregory
The
keyClass values are as follows:
- Playback Page +1: PlaybackPageUp
- Playback Page -1: PlaybackPageDown
- Go: Go
- Connect: Connect
- Cuelist +1: NextStep
- Cuelist -1: PreviousStep
For all of these the
group is
NoGroup.
Posted: 01 Sep 2018, 23:39
by kimwida
I think I found what made my midi triggers gone.
If there is already trigger settings on a pc and load a show file which have another trigger settings on the pc, the gone things happen.
(Actually both trigger settings are same, because I upload my show file from my home to cloud and download it to my club.)
Titan doesn't save trigger settings in show file but in local pc or console somewhere.
So it looks like there is some conflicts with both trigger settings and gone when it load show file.
When I loaded the show file in new fresh PC, it showed my disappeared midi settings.
But after I loaded a show file which I downloaded from my cloud, they are all gone again.
Posted: 02 Sep 2018, 10:01
by Gregory
Prior to version 11 all trigger mappings are stored on a per console basis, meaning that if you use the same show file between multiple consoles each will have a separate set of mappings. If you load the show onto a new console the mappings from the first console will be loaded. In version 11 show files trigger mappings are now stored globally so you will get the same mappings on all consoles although at the point you upgrade a v10.1 show file to v11 it will load in the same way as previous versions.
Posted: 30 Sep 2024, 04:56
by kimwida
Hi.
I am trying to add midi triggers for my apc mini mk1 thru a macro.
I succeed to work midi triggers apc mini buttons with my T2 ver.14.0. But I can't with apc mini faders to main playback faders.
I think that I follow the avolites wiki exactly.
https://www.avosupport.de/.../triggers...
https://www.avosupport.de/.../fun.../tr ... iditriggerAny advice appreciated.
<?xml version="1.0" encoding="utf-8"?>
<avolites.macros>
<macro id="Add_Trigger_For_APC_MINI_MK1">
<name>Add_Trigger_For_APC_MINI_MK1</name>
<sequence>
<!-- Add midi trigger apc mini buttons on the playback windows. It works. -->
<step pause="0.01">Triggers.AddMapping("APC_MINI_MK1", 8655)</step>
<step pause="0.01">Triggers.SelectMappingByName("APC_MINI_MK1")</step>
<step pause="0.01">Triggers.SetPendingTargetHardware("PlaybackTouch", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", OnSelect), "PlaybackWindow", 0, "Touch")</step>
<step pause="0.01">Triggers.AddSAcnTrigger(Triggers.SelectedMappingId, Triggers.PendingTriggerTarget, 8, 56, 1, false)</step>
<step pause="0.01">Triggers.ClearPendingTrigger()</step>
<step pause="0.01">Triggers.ClearSelectedMapping()</step>
<step pause="0.01">Triggers.SetPendingTargetHardware("PlaybackTouch", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", OnSelect), "PlaybackWindow", 1, "Touch")</step>
<step pause="0.01">Triggers.AddSAcnTrigger(Triggers.SelectedMappingId, Triggers.PendingTriggerTarget, 8, 57, 1, false)</step>
<!-- Add midi trigger apc mini faders on the main playback faders. It doesnot work -->
<step pause="0.01">Triggers.SetPendingTargetHardware("PlaybackFader", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", "OnValueChanged"), "Playbacks", 0, "")</step>
<step pause="0.01">Triggers.AddMidiTrigger(Triggers.SelectedMappingId, Triggers.PendingTriggerTarget, 1, Math.ToEnum("Avolites.Titan.Controllers.Console", "Avolites.Titan.Controllers.Console.PanelMidiCommands", "Continuous"), 47, 0, 127,0,false)</step>
<step pause="0.01">Triggers.SetPendingTargetHardware("PlaybackFader", Math.ToEnum("", "Avolites.Menus.MenuEventTypes", "OnValueChanged"), "Playbacks", 1, "")</step>
<step pause="0.01">Triggers.AddMidiTrigger(Triggers.SelectedMappingId, Triggers.PendingTriggerTarget, 1, Math.ToEnum("Avolites.Titan.Controllers.Console", "Avolites.Titan.Controllers.Console.PanelMidiCommands", "Continuous"), 48, 0, 127,0,false)</step>
</sequence>
</macro>
</avolites.macros>
