How to copy/transfer a macro into a Layout using AddLayoutElements?
grst_opt
Postby grst_opt » 28 Aug 2025, 01:40
Hi everyone,
I’m trying to figure out the correct way to place a macro from the Macros window into a Layout via XML / ActionScript.
So far I tried something like this:
<step>Layouts.AddLayoutElements(handle:"Location=Layouts,1,1",
handles:"Location=Macros,1,11",
x:0, y:0)</step>
…but it doesn’t seem to work. The macro gets selected, but nothing is actually added to the Layout.
I also tried with Handles.SetSourceHandleFromHandle before calling AddLayoutElements, but still no success.
What is the correct method to either copy a macro into a Layout or transfer/link it there programmatically? Do I need to use AddSelectedHandleToLayout, or is there another approach for macros specifically?
Re: How to copy/transfer a macro into a Layout using AddLayoutElements?
Postby Gregory » 29 Aug 2025, 19:42
Please try the following:
<step>Layouts.AddLayoutElements("Location=Layouts,1,1", handle:"Location=Macros,1,11", 0, 0)</step>
In macro scripts handle: or similar indicates that the value should be converted to the type preceding the colon. This is only necessary if an conversion cannot be detected automatically so in the above although you could write handle:"Location=Layouts,1,1" for the first parameter, this is inferred by the type the function is expecting. In the case of the second parameter there are two steps to the conversion, the first is to convert the string to a single handle and the second (which is again inferred) is to convert that into a list of multiple handles (even though the list only contains a single item). If a cast is not specified the software will attempt to split the string on the commas and then convert each part as a separate handle which wouldn't work when the parts are supposed to form a location.
grst_opt
Postby grst_opt » 31 Aug 2025, 17:06
Thanks a lot, your code works — I can see in the history log that the action was executed.
The only issue is that I don’t see the macro appearing in any of my layouts after running it.
Do you know what could be the reason for this?
Postby icke_siegen » 01 Sep 2025, 09:12
Do you have the macro and the layout in the respective locations which are referenced in that macro? I just tried this and it works for me:
  • Location=Layouts,1,1 refers to the first layout button in the first layout page - does this exist?
  • Location=Macros,1,11 refers to the 11th macro on page 1 in the macros workspace window, does this exist?
  • with both existent the final 0, 0 denotes the target position: the macro is moved to the top-left position in that particular layout
grst_opt
Postby grst_opt » 04 Nov 2025, 23:11
Yes, I do have the macro in the correct location, and I also have the layout in the correct place.
When I run your macro, the history shows that the “Add Layout Element” action has been executed — but nothing actually appears in the layout.
However, if the macro I’m trying to add doesn’t exist, or the layout doesn’t exist, then the command doesn’t execute at all and nothing shows up in the history.
So the system clearly *tries* to do something, but visually nothing changes.
Any idea what could be causing this?
