I have a chase with many cues.
All cues contain intensity information from 1 fixture group and off course many other attributes.
Is it possible to delete all intensity data, and only intensity data, from all cues in the chase in one time?
So far I haven't found how so I intend to open each cue one by one and change 'I' to 'off'.
I hope there is a faster way to do it all at one time.
After the handling all other attributes should still exist in the chase.
Remove intensity data in all cues in a chase at 1 time
Re: Remove intensity data in all cues in a chase at 1 time
Select the fixtures, set Dimmer to 'Off' and merge this into all cues:
- either you open the chase in playback view, press record and swipe over all cues
- or use syntax: with the chaser connected and the dimmer=Off in the programmer type <Record> <Cue/Connect> 1 <THRO> 100 <ENTER>
Thanks, that what I need to do!
