In short, this would work:
<macro id="UserMacro.ColChsOddEven.3">
<name>Col Chs O/E 3</name>
<sequence>
<step pause="0.01">Handles.SetSourceHandleFromHandle(Handles.GetHandle("Playbacks",1,6))</step>
<step pause="0.01">Handles.ConfirmDelete()</step>
<step pause="0.01">Handles.SetSourceHandleFromHandle("Location=PlaybackWindow,2,85")</step>
<step pause="0.01">ActionScript.SetProperty.Enum("Handles.OperationMode", "copy")</step>
<step pause="0.01">Handles.CopyDestination("Playbacks",6)</step>
<step pause="0.01">Handles.ClearSelection()</step>
</sequence>
</macro>Apart from the issue I already mentioned (CopyDestination needs the index on the current page), the other problem was in this line:
Handles.SetSourceHandleFromHandle("PlaybackWindow",2,85)The function SetSourceHandleFromHandle() requires a handle object as argument which can be given as handle object, as location, as user number, or as titan ID. You provided the location
parameters (handle group, page, and index) but not the complete location string, which is also the reason the Log Viewer shows something like 'error with number of parameters'.
The first line in your macro does work:
Handles.SetSourceHandleFromHandle(Handles.GetHandle("Playbacks",1,6))Here the inner function GetHandle() takes the location parameters as arguments and returns a handle object which SetSourceHandleFromHandle() happily accepts as input.
In my working version I merged the location parameters into a location string:
Handles.SetSourceHandleFromHandle("Location=PlaybackWindow,2,85")You could as well use the GetHandle() function here:
Handles.SetSourceHandleFromHandle(Handles.GetHandle("PlaybackWindow",2,85))would work as well, but with different numbering (see below).
Finally please have a look at the 0-based numbering:
Handles.ConfirmDelete() deletes playback 7 on page 2 (regardless what the current page is) - this is 0-based.
Handles.SetSourceHandleFromHandle("Location=PlaybackWindow,2,85") defines the source for the following copy operation as slot 85 on page 2 in the playbacks window (1-based).
Handles.CopyDestination("Playbacks",6) copies to slot 7 in the
current playbacks page.
Best regards, Sebastian
