Bug? Autoload does not "Go On Target" for chases
Posted: 18 Oct 2021, 11:09
Titan Go V15
Autoloaded chases do not "Go" when autoloaded with [Go on Target] option.
Repro as follows -
1. Start new show
2. Create a 4 step chase
3. Set Link on each step of chase to [Wait For Go]
4. Create a 2 cue list
5. Add the previously created chase to the Autoload for each cue of the list and set the autoload option to [Press Go On Target]
6. "Go" on the cue list
7. Observe, each go on the cue list will load the chase but the chase step/cue does not go.
This issue is only present for autoloaded chases, cue lists work as expected.
The setting of the chase step links to [Wait For Go] is for clarity of the repro only as I would assume that [Go On Target] on a running chase step with [After Previous] link would (when working as expected) advance to the next step in the sequence?
Repro as follows -
1. Start new show
