Bug? No access to "Tracked Values" options for Copy Cue syntax
Posted: 01 Nov 2020, 11:19
Titan Go v14
When copying a cue using syntax only, there is no access to the "Copy/Don't Copy" Tracked Values options.
For example, to copy cue 3 to cue 7 using the following -
I would expect after pressing the cue number (3) that an option to copy or don't copy tracked values to be available from the softkeys. Although the option is not accessible, the current value of the option is applied during the copy operation.
The options I'm referring to are available when selecting the cue to be copied from the cue list's playback view window, i.e with the cue lists playback view window open hit <copy> then select the cue from the playback window, you will see after selecting the cue the tracked values option is present on softkey C.
<Copy> <cue list handle> 3 @ 7 <Enter>
